How to lift 3 point implement with out tractor running.
   / How to lift 3 point implement with out tractor running. #2
I like to file worthwhile tractor tips in my brain BEFORE I have the need. So simple; so potentially useful.
Thank you for posting.
   / How to lift 3 point implement with out tractor running. #3
Certainly will not work on all tractors!
   / How to lift 3 point implement with out tractor running. #4
Thanks for posting this. Always need all the tips I can get. I don't own a MF or Ford N tractor but occasionally we move them about for neighbors. Good to know. Have a great day.
   / How to lift 3 point implement with out tractor running. #5
Actually....it won't work on MOST tractors.
That was the biggest downfall of the n-series. The hydraulics are driven off the PTO shaft. Similar to an external PTO pump like a backhoe attachment would have....just internal is all. So obviously spinning the shaft is operating the pump.
But it sucks when running. Because you have to have PTO running to raise implement. Hooking up to a tiller or bushhog....DONT hook up PTO shaft. Raise implement first THEN hook up shaft. And hopefully you don't have hydraulics that bleed off that fast.
Ever wonder why old farmers always set PTO implements like that on blocks? Now you know.
Almost all tractors made after the era of the n-series Ford's....this simply won't work on. And if you have an overrunning clutch on your N...won't work either unless you take it off
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
1275 (A50490)
1275 (A50490)
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
Mini trencher attachment (A53421)
Mini trencher...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
Please support our site by disabling your ad blocker.
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
