dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,574
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
For those of you who seem to have no issue with this, goody for you!
For the rest, my friend and I struggled with getting the tires lined up the first time we did it (Getting them off was not hard...). The result was the threads on the studs got damaged from that and required chasing. I was trying to avoid making that worse and actually learned something from my first try. The first tire went on reasonably as you could raise/lower the tractor to align and free rotate the axle to line up holes, but the second one was much harder as the first tire would hit the ground and prevent the axle from turning. You can't lift and roll these a little bit to line them up, so you struggle.
Besides, it was a quick, easy and fun little project and made my life easier. I'm all for making my life easier. I had a pretty good solution at hand with the lifts I had, so I did it. I was happy with it, so I thought I would share, that is all. I could see the grease trick working good too, though a bit messy. I'll save that one in the back of my head.
