How to lift tailgate/ramp?
   / How to lift tailgate/ramp? #21
I used a garage door spring as well. I built a 2' verticle post out of 1"x1" square steel tubing, which I then bolted to the steel bar that is on the side of the trailer.Then I bolted a garage door spring to the top, then I took the other end and bolted it to the side of the steel lift gate. works great, it has been on there for 5 years. No problems.
   / How to lift tailgate/ramp? #22
I would like to see a picture. Just be careful with little ones around and fingers. Also may want to lace a piece of rope though the spring and tie it off one each end with slack to operate.. When they break they can do a lot of damage. Good friend in High School's dad had a brand new Ram and the spring broke the first day he had the truck in the garage. Went up the hood, across the windshield and over his camper top requiring repainting 60% of a 1 day old truck and a new windshield.
Chris
   / How to lift tailgate/ramp? #23
I liked your idea so I copied it :D but I used some 1-1/2" tubing I already had.With just one side with a 140# spring the gate lightened up from 45lb to 15lb,so I added another one to the other side.Too much spring now,so I took it to the machine shop and they are going to add a 1 ft extension accross the center 40" as I have some loading problems with impliments attached to the tractor.Been using a couple of loading boards but thats a pain.Here's some pics,and I'll add more when I'm finished.
   / How to lift tailgate/ramp? #24
you can also use some torsion springs on the hinge
2020 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A56129)
2020 VOLVO...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane (A55787)
1995 Koehring...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2020 Kubota M6H-101 (A53314)
2020 Kubota...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
