How to load trailer with 18 inch high sides with forklift with a long bundle
   / How to load trailer with 18 inch high sides with forklift with a long bundle #21
Empty pallets would seem the easiest and cheapest solution.
Converting to a stake side, or trading for a deck over might be the best, but is it worth the expense?
   / How to load trailer with 18 inch high sides with forklift with a long bundle #22
Cut the sides off.
On many utility type trailers the sides are an important structural member. Cut them off and the trailer will fold like a pup tent.
   / How to load trailer with 18 inch high sides with forklift with a long bundle #23
I致e never had a problem with the loading angle on my current deck over. Not all deckovers are created equal.
I rebuilt my own. 63cm deck height with 2.5 meter ramps make a very smooth angle. I built a tilt bed before, but hated the noise the frame made on the towbar, so i built mine as a low deckover. All it cant do is dump, but whenever i haul dirt behind my car instead of the tractor, its to a place where it has to be put on the spot with a wheelbarrow anyways.
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
Clemco 150psi Portable Sand Blasting Machine (A55973)
Clemco 150psi...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
