How to make rubber knob ends "stay put"
   / How to make rubber knob ends "stay put" #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
A couple people here and there have posted that the lever ends for things like the lift or PTO have come off on their Kubotas - and they are looking for ways to get them to stay attached to a painted shaft - here's a GREAT solution that works like a charm:
This is trick I learned from a golfer... Take some of the thin 2 sided carpet tape, put it on the metal shaft. Peel off both sides. Now douse the tape with rubbing alcohol - go ahead and pour it right on it. Then quickly slip the rubber cap down over the tape - the alcohol makes the sticky - not stick at all... then when the alcohol dries - the stick returns - and the rubber will not fall off - that's how they put grips on shiny metal golf clubs.
Now no more issues with the lift lever knob end coming off in your hand if you raise an implement quickly!
   / How to make rubber knob ends "stay put" #2
I used clear RTV. Squirt some in the knob and slide it on....stuck for good.
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
71065 (A49346)
71065 (A49346)
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
