How to re-paint a trailer hitch?
   / How to re-paint a trailer hitch? #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
Wife's Explorer trailer hitch has a lot of rust showing and she want's it painted. What is the best way to handle this project;
Remove hitch, use a wire brush to remove rust, clean and re-paint. Any other suggestions?
Thanks
   / How to re-paint a trailer hitch? #2
Probably not the way most people would do it, but I would remove the hitch, throw it away, & buy another one....
They always seem to rust from the inside of the tube out, making any repainting job look like **** in 12 months..
I'm sure everybody else will disagree...
   / How to re-paint a trailer hitch? #3
</font><font color="blue" class="small">( Remove hitch, use a wire brush to remove rust, clean and re-paint )</font>
Yes, that's just what I'd do, unless I had a sandblaster to use instead of the wire brush.
Thanks
Since we are probably trading the vehicle within a year, I'll give it a try to re-paint. I understand that the inside of the receiver will show rust and I can accept that. Just want to improve the exterior appearance.
Thanks for the replys.
   / How to re-paint a trailer hitch? #5
Put a wire wheel on a handheld grinder and go to town with it. When all the big flakes are off feather your edges with it real well, prime it with several coats then use a heavier duty equipment paint on it and you should be good. If you have access to a sandblaster that would help but it isn't really needed, I've done several without one.
It also helps to take it off of the vehicle if possible.
Birdhunter1
Thanks for the suggestion. I have been looking for a reason to buy an air powered grinder and it won't be a hard sell to the wife since its her idea.
   / How to re-paint a trailer hitch? #7
I've always just used an electric one, I didn't care for the air ones since it could only be used where you had a compressor with enough hose.
   / How to re-paint a trailer hitch? #8
I would just knock off the flaking pieces and leave the rust and use a rust converter like "Conquest" and it turns the rust into a hard black primer and then paint with a good quality paint. Make sure to use a rust converter that looks like a light tan colored milky substance. A lot of stores sell it under a generic "rust converter" label. As long as it's the milky looking stuff then it's ok.
I was skeptical of the stuff at first but I'm a believer now that we've been using it at work for about 5 years. I work on boats and see a lot of rust and the stuff works wonders and makes cleaning rust a lot easier and it's tough. I've seen boats come back that had Conquest applied and those areas are still rust free while other areas have started to rust and blister.
I've used it on my truck, trailer and tractor with great success.
   / How to re-paint a trailer hitch? #9
It's an Explorer, rattle can that thing real quick, then get on with your life. /forums/images/graemlins/laugh.gif The paint will out last the head gaskets.
   / How to re-paint a trailer hitch? #10
Air grinders can use a lot of air. Make sure you have enough compressor CFM or a large enough air tank to supply a grinder.
Set 4- 10-16.5 tires/wheel for bobcat (A55787)
Set 4- 10-16.5...
2019 Ford Explorer AWD SUV (A55758)
2019 Ford Explorer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55788)
2012 Chevrolet...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
20" Sea Container (A47384)
20" Sea Container...
