How to release hydraulic lines
   / How to release hydraulic lines #11
Sometimes it helps to push forward on the hose you are trying to pull out before pulling it out.
   / How to release hydraulic lines #12
:thumbsup:
I had the thought going through my head that your couplings were of the push/pull vintage.
Glad that you had the expert advise to get it figured out.
One reason I believe they were used, was with breakaway equipment that allowed for the hyd. hoses to disconnect without operator help, thus to avoid pulling a hose apart and have oil spraying all over.
Keep the area clean of dirt so it doesn't get into your hyd. system. The caps help that, but are not the complete answer.
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
2017 Ford F-250 Ext. Cab Pickup Truck (A55788)
2017 Ford F-250...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
New Powersmart 4400 Watt Portable Generator (A54865)
New Powersmart...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A55745)
2012 GALLEGOS 130...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
