How to remove Battery Cable bolt
   / How to remove Battery Cable bolt #11
using a hammer on the socket keep tapping the socket onto the nut, use a good shot of whatever pentrant you have to help, but getting it to start is half the battle, even if you twist/break off the the stud or the nut, your replacing the battery anyways, buy a new nut whan at the store.
heck, im assuming that this is a screw post terminal not a top post?? either way, tap a socket onto the nut and go for it. if its a clamp style/top post cable/connector, try using a dremel to cut the stud in between the to halfs of the connector, cover the battery to prevent sparks from possibly becoming an ignition source
I have some small gear pullers,, maybe I could get one of them on there and see what happens..
I don't think I have enought room to get in there with vice grips... but I have a good small pair...I might see if that would work....
   / How to remove Battery Cable bolt #13
Unhook the other end of the cables and get it out where you can work on it.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A54313)
2017 FREIGHTLINER...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
Flat Bed (A52377)
Flat Bed (A52377)
