3-Point Hitch How to remove pto shaft cover?
   / How to remove pto shaft cover? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Shaft is on a Bush Hog mower. Big plastic covers on ends of shaft surrounding the yokes. Need to remove the cover so I can take off the yoke for repair. It appears that the shaft and cover are Italian made, if that helps anyone. PTO Shaft 1.jpg So if I learned how to attach the pic, you can see the small gadget on the small end of the cover. A screwdriver can rotate it so the slot is in line with the shaft. In either position it can move just a little bit parallel to the shaft, but not enough to remove the cover. There are 4 of these and I am afraid if I use much force they will break.
So, how should I remove the cover?
   / How to remove pto shaft cover? #2
Can you not separate the shafts then slide the covers off the detached ends. It may need a bit of help (force) getting the bell ends off the universal joints.
   / How to remove pto shaft cover? #3
Good luck. I hate those things.
   / How to remove pto shaft cover? #4
Once you have turned those, simply pry them out with your screw driver.
   / How to remove pto shaft cover? #5
You can google "remove pto shaft cover" for videos and pictures. All the makers use different secretes to slide the cover off....it's like solving a puzzle.
My PTO shaft tips
   / How to remove pto shaft cover? #6
Me too. Mine is rolling around in the back of my truck. After removing it to grease the joints a few times I took it off and will not be putting it back on.
   / How to remove pto shaft cover? #7
What I’ve done on some is warm up the plastic with a heat gun and use a sharp knife to cut an access hole for your grease gun nozzle.
   / How to remove pto shaft cover? #8
You need to pop those clips up.
   / How to remove pto shaft cover? #9
Looks like the two knobs should be squeezed together then the latch will pass up. Repeat for the other latches. Then the whole cover slides on the shaft away from the joint.
   / How to remove pto shaft cover? #10
Because of frustrations with the OEM guard and some damage I bought a Bare-co cover for my Bush Hog, it was expensive but is easy to take off for greasing etc.
BareCo PTO Safety Guard - YouTube
It functions almost as easily as in the video.
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
