How to remove PTO shaft from slip clutch on rotary cutter?
   / How to remove PTO shaft from slip clutch on rotary cutter?
Soldier, the ring won't slide. It's snapped into a groove that's cut into the shaft, so you need to snap it out of the groove. First find the seam or gap in that ring. You'll need to pry one end out of the groove and work it around and out. Some snap rings have a hole in each end of the ring and are meant to be spread and removed with snap ring pliers. There's a snap ring in your picture, to the left of the one you're working on, inside the yoke. That ring is in the yoke (internal) rather than snapped on the shaft (external).
Okay. I'll head out with some needle nose pliers and see if I can pry it loose.
Thanks for everyone's advice. I'm not mechanically inclined. lol
   / How to remove PTO shaft from slip clutch on rotary cutter? #22
Why are you looking for a new slip clutch. That one looks like it can be cleaned up and the tension springs re-adjusted. Just remove all the bolts and springs while noting the number of threads on the bolts (you will need to put them back in approximately the same tension), then wedge between the hubs to separate them if they are rusted together. After cleaning off the rust etc. put the bolts and springs back in and tighten back to approximately same as when you removed them.
It should then work fine. If the U-joints are frozen, then some working in both direction should free it up. Grease it up good prior to trying to free it up.
Gary,
When looking for a new PTO shaft I saw that for $100 less than just the shaft at tractor supply I could snag a new shaft and slip clutch from agri supply. In the event this shaft turns out to be junk
Snap ring is off but the shaft still won't come off the slip clutch. Its hung up right at the end. Guess i'll have to drag it out farther where I can chain the cutter to the recovery hooks on the front of my truck then apply some tension with a chain to the drawbar
   / How to remove PTO shaft from slip clutch on rotary cutter? #25
Pull the shaft apart & clean it up & use it.
Chain the cutter to a tree or something solid & pull with tractor or truck.
Not long enough at current stuck length to connect to tractor PTO. Guess I could connect it to a clevis on the drawbar
You don't want to connect to the tractor PTO to pull on it. FIgure a way to hook a chain to the yoke and pull from the drawbar or something.
That's a funky design on that thing. Never seen a clutch AND shear bolt setup on the same shaft.
At any rate, now that you have the shaft pushed forward and the clip off you should be able to clean the end of the shaft with some emery paper and get it to slide right off. Then you still have to get the telescoping tubes to slide before you proceed. After all is sliding and connected you will have to loosen all the clutch bolts and get it to spin then tighten back to adjust.
   / How to remove PTO shaft from slip clutch on rotary cutter? #26
Tractor Guy, I'm shopping for a light weight rotary cutter, and I have a TSC nearby. All their brush hogs are shear pin only. But they sell a slip clutch that goes on an existing PTO shaft, so that is exactly the setup I would be looking at. Replace grade 2 shear pin with grade 8 and rely only on the slip clutch.
For those of us who do not like shear pins.
   / How to remove PTO shaft from slip clutch on rotary cutter? #27
The manual wasn't much help as there wasn't a section covering PTO shaft removal. Any help appreciated
TSC has a manual for their brush hogs available online, with pretty good pictures and instructions. Bring up one of the cutters, scroll down to "More Info", click the down arrow and there is the manual.
   / How to remove PTO shaft from slip clutch on rotary cutter? #28
Progress! Good deal. That's not unusual to get hung up on the end since that tip was exposed and has more rust, dings and dents. You might have created a burr on there when pounding that yoke and ring. Push the yoke back on and see if you can clean the end of shaft a bit with a wire brush and/or fine sand paper/emory cloth or even a file.
   / How to remove PTO shaft from slip clutch on rotary cutter? #29
I put a nylon strap through the PTO yoke so it pulled straight, chained a comelong onto that and applied tension. Soaked the heck out of it with PB Blaster. Did TAP Tap Tap on the side of the PTO shaft. Not real hard hits, just enough to dislodge it. Repeat if necessary. Softer touch did better than brute force.
SUCCESS!
Used an axle strap through top link to pick up front of cutter and drag it into yard where I could get my truck behind it. Ran a chain from recovery hook to the cutter, then another chain from front of pto shaft to clevis on draw bar on tractor.
One tug popped it off.
Re-positioned and ran chains from each end of PTO shaft to truck and tractor.
Didn't want to go first pull, so put RPM up to 2,300 and did a full send. Popped apart.
Tomorrow going to hit it with brake cleaner to clean it up then grease and re-assemble. Hopefully it is the right length.
Still need to unbolt and clean slip clutch then re-assemble and adjust.
Thanks for all the advice gents!
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
2015 INTERNATIONAL DURASTAR 4300 (A58214)
2015 INTERNATIONAL...
Bucket (A55973)
Bucket (A55973)
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
2022 Coras Predator Steel End Dump Trailer (A56435)
2022 Coras...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
