How to repair leak on GC2310
   / How to repair leak on GC2310 #51
There is no need to buy any kit to fix this leak.
All you need to do is replace the o-ring on the shaft seal with a 3/4 X 15/16 X 3/32 (ID/OD/section) which you likely have on the shelf somewhere if you have a standard o-ring kit.
To get the steering wheel off use the method described by Ray66V - loosen the nut until it is flush with the shaft, brace your knees under the steering wheel and apply upward pressure, place a large brass drift on the nut/shaft and strike it with a hammer, two blows and the wheel will be off - no damage done.
Disconnect the pump - label the hoses
When you have the pump on your bench scribe the sections so you know how to line it all back up when assembling although it does not really matter as the pump is symmetrical just make sure you know which hole the bolt goes in and you can figure that out with the pump apart as it is the only dead hole.
Polish the rust off the shaft and lubricate so you do not damage the dust seal when removing the spool.
When the pump is disassembled remove the spool (part the steering wheel attached too) make sure both washers and the bearing come out as well (#7 page 4 in the PDF provided by Mac Clarke) and push the seal out (part 5) with your finger nail or really light pressure with a screwdriver (it was teal in colour on my pump)
Replace the o-ring with a 3/4X15/16X3/32 o-ring and reassemble
Done
Cost < $1
This is how I fixed mine
   / How to repair leak on GC2310 #52
Done
Cost < $1
My steering unit was leaking and since I stopped using the steering wheel for leaverage eventually the leak stopped. Hope I never have to take this apart to fix.
   / How to repair leak on GC2310 #53
I have a 2300 with the same problem, for a temporary fix i used a rag and wrapped it around the bottom off the steering wheel where it connects to the shaft. this put a little up pressure on the shaft and it stopped leaking which give me time to get the seals.
   / How to repair leak on GC2310 #54
Reviving a really old thread...having said that, I have a couple of questions. The pressure port on the steering motor has a ball and a ball stop. Does anyone know the proper orientation and placement of these two parts. I assume the ball is placed into the pump body first followed by the ball stop (about 1" long with a small forked end). Any help would be appreciated.
   / How to repair leak on GC2310 #55
Mustangsallysdad, did you figure it out? I'm on the road this summer and haven't been keeping up with TBN. I bet my service manual could help, but of course didn't bring that along. ijk
Case SC Tractor (NOT RUNNING) (A50775)
Case SC Tractor...
PALLET OF MILITARY STRAPS (A54756)
PALLET OF MILITARY...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2006 Pierce Quantum Hale Pumper Fire Truck (A55788)
2006 Pierce...
202473 (A54757)
202473 (A54757)
