How to replace a backhoe stabilizer seal
   / How to replace a backhoe stabilizer seal #11
I open my cylinder up and the problem seal is a small plastic flange piece that I would call a dust seal. It is broken around the outside edge. It is at the end of the shaft where you screw it back together. I assume it has come in contact with a rock or something hard when the stabilizer was retracted? It is just a little larger than a quarter. I attached a picture.
That is not going to be your problem.
That doesnt seal hydraulic fluid....it simply is just a dust seal to protect the main hydraulic seals in the gland. And there are several types......the most common two I have seen are lip seals and simply o-rings.
They would be further down inside the gland cap that seals the gland to the rod. So basically where you got that seal from.....but down inside the cap a little further.
And I have always just taken seals, gland, and rod to a local hydraulic shop and have them simply match them up
That may be what I end up doing? I have a small tractor dealer that I plan to visit Monday.
Cylinder repaired, tractor backhoe back to work! I found a cylinder repair service and he took my and Gland & Piston and put all new seals and o-rings in place and handed it back to me and only charge me $30. I told him to give me another set of seals to go. I have several more cylinders just like that one.
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
