How to seal diesel pump hose threads
   / How to seal diesel pump hose threads #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
I noticed that my relatively new to me 250 gal diesel storage tank hose/pump assembly is leaking where the hose threads onto the pump handle (I have a Tuthill Fill-Rite Fuel Transfer Pump — 12 Volt, 15 GPM, Model# FR1210CANT attached). When I first installed this pump/handle assembly, I used teflon tape thread sealer, but noting that this is still causing some minor diesel staining/leaking, I saw that the local gas QuikTrip gas station uses some sort of grey sticky substance to seal their hose threads to their pump handles. Does anyone know what this stuff is or are there other suggestions out there for what sealing stuff to use?
   / How to seal diesel pump hose threads #2
Permatex pipe dope would be my choice. It's black and goes on like thick tooth paste. If you're going to get some get the non-hardening formula. Pretty sure Auto Zone sells it.
   / How to seal diesel pump hose threads #3
I'd say pipe dope too, I use the "Blue" stuff with teflon in it, lay on a good layer and tighten her up, then wipe of the excess - should do it......
Thanks, guys. Is the black or blue pipe dope any different from the white dope that I have used previously in water plumbing applications (that I already have some of...)?
   / How to seal diesel pump hose threads #5
Read the label. My white pipe dope claimed to be compatable with petroleum.
   / How to seal diesel pump hose threads #6
   / How to seal diesel pump hose threads #7
Some paste-type pipe dope has teflon and is very resistant to almost everything (and is better than teflon tape). Some does not and is only good for some applications.
   / How to seal diesel pump hose threads #8
This is all I have ever used working with diesel fuel and it works great (I think this is what others are talking about here)...
Read specs HERE
The only thing I could say to you, make sure you do not get any of the sealant near the opening of the fittings where it could enter the fuel. After time this stuff dose get hard as a rock, but don't worry it is still very easy to remove (flakes off of fittings when need be or use of a wire brush)
2016 CLUB CAR (A53424)
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
Manac Walking Floor Trailer (A50322)
Manac Walking...
SLIDE MASTER ALUMINUM SLIDES (A54757)
SLIDE MASTER...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
