Choosing the right hydraulic breaker for an excavator requires careful consideration beyond just matching sizes. It’s essential that the breaker’s specifications align with the carrier’s weight class, hydraulic flow, and operating pressure. Breakers that are too small may not perform effectively, while those that are too large can potentially damage the carrier. Contractors should also consider factors such as tool diameter, impact frequency, and the hardness of the material being worked on. For instance, mid-sized breakers are often suitable for reinforced concrete in urban settings, whereas quarrying operations typically need high-powered models for effective rock fragmentation. Selecting the appropriate breaker can enhance efficiency and prolong the lifespan of both the excavator and the attachment. It is advisable to consult manufacturer charts or expert suppliers for optimal choices.
Operators should consider:
The impact power of hydraulic breakers.
The quality of breakers.
Easy maintainable hydraulic breaker.
Could reduce the operation time and cost money.
If there is any other source about this topic your are welcome!
