No, I am not talking about the two speed powershift button. Nothing wrong with that. It is the power clutch button that they've just added with it, which allows you through the synchromesh gears by using a button clutch instead of a foot clutch. I am not sure, but the button clutch wouldn't let you change gears under power, so it wouldn't be the same as a powershift.
radman1 said:I am mostly familiar with JD and CNH transmissions. The push button shift you refer to is found on CNH's 24x24 transmission. It actually is great if one needs to downshift on tillage work. Say you are discing or plowing and encounter a steep hill, by downshifting with the button, the tractor gets about a 20% decrease in speed and 18% increase in torque to make it up the hill. Get to the top of the hill and upshift with the button. No stopping to clutch and shift gears. In a full days work this couple happen a lot. For most heavy work, often a single downshift is enough to get you through the tough spots. To me it works like the torque amplifier of the older tractors.
JDs quad shift and CNHs semipowershift lets one change gears in a single range without clutching by moving a shift button. (four gear shifts)
Full powershift is nicer and lets you change through all gears without clutching.
JDs IVT (infinitely variable transmission) lets you move a lever seemlessly throughout without clutching. Touch the brake and the tractor stops without clutching. Release the brake and starts moving again. IVT is a fantastic transmission from what I have heard but $$$$.
On top of the semipowershift, full powershift and IVT you can get autoshift which will let the tractor shift up and down in field or road modes depending on engine speed and how fast you want to go. Now you don't have to do any button shifting.![]()
