How to shorten hay elevator chain?
   / How to shorten hay elevator chain? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
I have a old New Holland tube steel type hay elevator with the center "detachable" chain. Every 10 links or so there is a spike that grabs the bale.
The chain links are sort of like one side of an apron chain you'd find on old equipment, or a manure spreader, etc...
Looks something likes this: Steel Detachable Chain (1' Roll) | Agri Supply 11367
I want to shorten the elevator by unbolting and removing a middle section of it and will need to shorten the chain when reassembled. I looked for a master link to no avail. Looking at the above link, I don't think they have any.
Looking for tips.
What's a good way to break chain to shorten and how to reconnect links? Heat? Big hammer and chisel?
How to reconnect?
   / How to shorten hay elevator chain? #2
Every link is a master link. You fold over a link 90 degrees so the slot of one lines up with the side of the adjoining link. You rest it on something solid (that allows a slight over hang) and hammer the adjacent link through the slot. It is a tight fit, so you do have to hammer it. Just make sure the slot is lined up well. Reassembly is pretty much the same thing.
   / How to shorten hay elevator chain? #3
   / How to shorten hay elevator chain? #4
Last night I sprayed with penetrating oil all the bolts that hold an individual elevator tube segment to adjacent segments. 28 bolts that haven't been turned probably in over 40 years.
Regarding the chain: I loosened the adjustable tensioner sprocket at the top end of the elevator to get as much slack in the chain as possible, but that doesn't provide enough slack that I can fold the chain over on itself to take apart or to get it off (to the side of) the end sprocket to get more slack.
I'm thinking I need to take a fencing (block and tackle) pulley (or a come-along) and start pulling the chain loop unto itself (if that makes sense) to create slack. But the chain slack this creates will be right under the come-a-long which will be right in the way.
An easy work-around solution to getting enough slack may become apparent when I actually do this, but any tips?
   / How to shorten hay elevator chain? #7
These guys have all the parts you will need.
Forage Wagons / Cross Conveyors | albusconveyors.com
Home
Spreader Chain
Bunk-Feeder Chain
Cross Conveyors
1-800-982-1183
Contact Us
Search
Home
/ Forage Wagons / Cross Conveyors
CROSS CONVEYORS
CROSS CONVEYOR SIDE CHAINS ONLY
PATZ STEEL FLIGHTED CONVEYOR CHAIN
Slat Sizes
NEW HOLLAND ROUND BALER CHAINS
KELLY RYAN FEEDER WAGON CHAINS
ELEVATOR-CONVEYOR CHAINS
Hesston Stacker Side Chain
P.O. Box 100 • Ladysmith, WI 54848 • 1-800-982-1183 • 715-532-6060
© Copyright 2019 Albus Conveyors, INC.
   / How to shorten hay elevator chain? #8
If you work that middle section of the elevator out you will have all the chain slack you can stand.
On this model, the chain on the underside of the elevator runs inside an enclosed metal channel. That is, each section’s channel connects to the next to make a continuous enclosed chain on the underside. It is safer than the ones I grew up with.
Bottom line is the middle section can’t be removed unless the split chain is pulled out of the connected channels.
   / How to shorten hay elevator chain? #12
I have placed a pry bar in the links and leveraged them up to drive apart,
it doesn't take much slack that way.
Thanks Lou.
If I understand you right, pick a link, say link #1 and weave the pry bar through link #1 and link #4, leverage them together so that links #2 and #3 between them are slack?
   / How to shorten hay elevator chain? #14
It has been a while since I had to mess with those types of chains, but yes if you can get a small bar in and 2 and 3 stand up they should make a 90 and be able to drive apart. You may be able to bring them together with a big pair of channel locks also.
Sometimes you can work right at the lower sprocket also.
   / How to shorten hay elevator chain? #15
Youre going to shorten the chain anyway, so why dont you just cut a link to separate the chain. Itll give you all the slack you need without force/stretching it.
Good point.
That’s the usual method anyways right?
If pounding on something doesn’t get it apart, get the grinder
...or the torches.
Volvo EC220EL (A60462)
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
PALLET OF CHROME FENDER FLARES (A60432)
PALLET OF CHROME...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2020 Toyota Tacoma Crew Cab Pickup Truck (A59230)
2020 Toyota Tacoma...
Kuhn FC400RG (A60462)
