How to tie knots when pulling trees?
   / How to tie knots when pulling trees? #1
frank29
Atlanta, Georgia
I'm in the process of cutting down several dozen trees lining a gravel drive before I concrete the drive. I am using a cable come along winch and rope on the larger trees to avoid having them fall into dense woods and getting hung up.
The problem I am having is loosing the knot after the tree falls. Is there a type of knot that would be easy to undo after being under substantial pressure?
Is there a better method to connect both ends of the rope other than knots?
Thanks for any help.
   / How to tie knots when pulling trees? #2
Well you could tie a loop into the end of the line using a Bowline knot(rabit comes out of the hole, over the log, around the tree, back over the log and back down the hole). This not can usually be undone fairly easilly, even if strained(bend thetree back over the log, and slid the rabbits path around the tree up and over to loosen). But if you use it to make a small loop, you can join it back to the main line with a shackle or snap clip. That way you don't have to do any more tying, just use the shackle or shap clip to do the connections around the tree. The shackle will also allow the end to slide like a noose and tighten around the tree.
As when using any line for this type work, watch out for snap-back. A line can store a tremendous ammount of energy when stretched. If something should let go, it is never a good idea to be near the lines path, especialy if htere is a heavy metal fitting on the end of that line. I know that is hard to do when using a comealong, but something as simple as a coat layed across the middle of the line under tension, can dampen and re-direct the line's recoil into the ground if something should let go.
   / How to tie knots when pulling trees? #3
Bowline
The Bowline
Best knot site I have found, There are lots of other knots on there, but really the Bowline is the one to use.
   / How to tie knots when pulling trees? #4
Get a half decent cable choker.
I wouldn't mess with "rope", it too elastic and DOES break under the sort of forces that you need to use to pursued trees to move.
   / How to tie knots when pulling trees? #5
When tieing your knot just put a stick in it. Take out the stick and you should be able to on tie your knot.
   / How to tie knots when pulling trees? #6
Hi Frank,
The bowline is a pretty utilitarian knot, and doesn't ordinarily bind, but cuts the breaking strength of your rope by something like 40%... the Timber Killick is one that will come untied very easily and will ensure a directional pull on your logs, keeping them from turning or dancing around as much...
My favorite knot is a modified midshipman's hitch (with turns opposing traditional tying), which is a "slide and grip" knot which will form a dogleg on your rope to bind at whichever length you slide it to. It is great for any sort of tensioning you need to do, is very easy to tie, and to date has never bound up on me thanks to the extra wrap in the line.
To join two lines without binding: a rigger's bend, a zeppelin bend, or a sliding figure of eight bend will all allow untying, be secure, and maintain most of the line's strength.
Geoffrey Budworth would be a name you could Google to get a ton of ideas... those 3 would be my choices for your need.
Have fun!
   / How to tie knots when pulling trees? #7
If you have to use a rope instead of a chain or cable the knot I'd recommend is called a timber hitch. It's not hardly a knot in the truest sense as the "dead" end of the rope is just looped back & then wrapped around it's self several times. The friction of the rope wrap on the bark will hold it in place.
Timber hitch - Wikipedia, the free encyclopedia
This shows how to tie it.
Thanks to all! Maybe my rope will stop getting shorter; about every other tree, I've been getting frustrated and just cutting right at the knot.
Thanks again.
   / How to tie knots when pulling trees? #9
I would use one of my big clevises and tie off to that. The clevis can be opened and accept the loop of rope for a choker. Undone to move to the next tree.
24in pin on tooth excavator bucket (A56438)
24in pin on tooth...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2020 DRAGON ESP...
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
