How to weld in a straight line?
   / How to weld in a straight line? #31
I use a (lense) cheater but it hasn't helped much. Just curious. How can more light help? How can you have more light than created by the arc, or is the angle/location an issue? I could do some really nice welding if I could only see what I was doing.
I know a 60 year old guy who has welded all his life, every day (Sunday's included). He doesn't wear glasses but does need more and more light in his shop to see what he is doing, but not welding. He can see perfectly when welding. So is this issue all about bad eyesight?
I like it bright before I start the arc because I can see what I'm doing through the permanently dark helmet. After the arc is starting I don't notice any difference in the ambient lighting.
   / How to weld in a straight line? #32
This has worked for me. I do wear bi-focals and use an auto dark Hobart helmet with shade 10. Remove the head harness and use stick-on velcro to attach the light to the helmet. Yes, the light gets messed up but at $2.99 a pop I can afford to replace it when needed. Swivel Lens Headlamp
   / How to weld in a straight line? #33
Unless it's really hot/humid out (and sometimes even then) I find it easiest to wear a hooded sweatshirt and put the hood up over my head. That blocks any ambient light from making it into the back of my welding mask. Sometimes a bright light is needed on the work piece, depends on the situation.
   / How to weld in a straight line? #34
If you can't see the puddle (or joint ) while welding, don't be afraid to reposition your head for a better view. In - out - up - down - left - right whatever it takes.
You'll refocus when it's your flannel shirt that's on fire!!!!! Those old insulated flannel shirts that used the slick nylon material in the sleeves burn like gasoline!!!!
   / How to weld in a straight line? #35
I've breen trying to figure out why more light helps, myself. After I ran a bead in insufficient light and raised my hood to discover it didn't even hit the joint :ashamed: I tried more light. To my surprise it was a great help. I believe I got the advice to use more light from this forum.
   / How to weld in a straight line? #36
I think the bright 'background' light might help with the contrast or in other words, reducing the range of luminosity your eye must process to see bright and dark areas at the same time.
   / How to weld in a straight line? #37
X2. The throw-away LED light makes a major improvement.
   / How to weld in a straight line? #38
I'm going to give this a try, as I prefer to use a little darker lens shade to protect more which causes a harder to see work zone, the ambient light around the arc but in the work zone might just be the ticket. Thanks
   / How to weld in a straight line? #39
$2.99. That's insane. Its a couple hundred miles to the nearest HF, but guess I'll have to swing by next time I have to go to Denver.
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
2006 BMW 325i Sedan (A55853)
2006 BMW 325i...
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
2018 K-TEC 1228 PULL TYPE DIRT PAN (A52707)
2018 K-TEC 1228...
1840 (A51248)
1840 (A51248)
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A52707)
2017 GENIE GTH-844...
