repete
Veteran Member
You will enjoy this unit. I have an L2550DT (29 horsepower) about a 1984 model and have used and abused this little guy and it comes back for more every day. It now has a little over 5100 hours but runs very well and uses no oil. Spent the day on it dragging out about 5 of about 40 acres of pasture with a 10' harrow with a 10' 10" I beam on it for weight (The harrow by itself is heavier than the loader can lift), put on a two bottom plow and cut a ditch and removed the dirt with loader.
Your tractor will last you a long time with a little regular preventive maintenance. I grease mine regularly (looks greasy and gross though but I use it and do not go in parades) and change the oil and filter every 100 hours like clockwork and the hydraulic fluid and filter every 750 hours. I suspect yours has the "pusher" fan as mine does so knowing how the clean the radiator screen is a good thing to know. Replaced the loader bucket a couple years ago as it was way too bent and front edge was torn up badly and I could not easily scrape out the barn.
