Howse or Leinbach PHD
   / Howse or Leinbach PHD
Thanks Brian, I have 3-4 weeks to make up my mind.
I'll let yuo know what I decide.
David
   / Howse or Leinbach PHD #12
</font><font color="blue" class="small">( One advantage of the Harvard PHD is that if you drill the auger in and can't pull it up, you don't need to stop the tractor, get off, detach the auger and manually unscrew it out of the ground.
...they can talk their way out of anything, without help. /forums/images/graemlins/grin.gif
But you're right, they're still overpriced. /forums/images/graemlins/wink.gif )</font>
no silly, with his Harvard PHD all he would have to do is to put his PTO into reverse.
   / Howse or Leinbach PHD #13
I have a Howse PHDL15. It's listed as the light duty for use with 20-30 horsepower. I am using a 9" and 6" auger. The next one up is the PHDM for 30-40 HP and the PHDH fjor 40-50 HP. If you get a heavy duty make sure your equipment can handle it. I would prefer a heavy duty model, but am limited to 27 hp on my tractor.
Question concerning auger size.
I found some Creosote 6x6 beams that I can saw some good corner post and post for gate. I plant to cement at least the post for the gate (other post on the fence line will be t-post).
I was planning on getting a 9" auger, will this be sufficient or should I also get a 12"auger for the 6x6?
   / Howse or Leinbach PHD #15
hunterridgefarm, minimum of 12" hole for a 6" post. A 6x6 is 7 3/4" diagonally, not much room left for cement in a 9" hole.
Brian /forums/images/graemlins/smile.gif
Brian,
Thats what I was thinking...but since I have always used the manual or the 2-man post hole digger and then the manual if the hole was not big enough, I wasnt sure.
Thanks,
David
   / Howse or Leinbach PHD #17
hunterridgefarm, Have you tried thesmartfarmer.com. I see you're in western NC. He is in East Tenn. Might be close enough to come and pick it up. I have bought from him and was satisfied.
2012 VANGUARD 53FT DRY VAN TRAILER (A53426)
2012 VANGUARD 53FT...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2017 John Deere Z970R (A50123)
2017 John Deere...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
STORAGE FEES (A53426)
