HP Requirements for Field Cultivator?
   / HP Requirements for Field Cultivator? #1
Huntshillhaus Farm
South Central Missouri
John Deere 2150, Husqvarna Z554
How much tractor weight and HP is needed to pull something like this 10.5' Cat 1 field cultivator?
   / HP Requirements for Field Cultivator? #2
I'm going to guess it depends on what type of soil and terrain. I'd guess something in the 8k plus range for weight and probably 70+ for HP, real row crop tractors are a different animal.
I'm wanting to use it after running over things with a disk. I'm in the market for either a plow/disc/harrow combo for soil prep (I live in the Ozark foothills with lots of rock), or springing for a 6' tiller. I much prefer the tiller option, as I have broken lot of ground with a borrowed tiller, but they are climbing so fast in price I can't be sure to find a decent used one without driving three states away.
   / HP Requirements for Field Cultivator? #4
Your JD 2150 is probably more than plenty.
But that thing dont look anywhere near 10.5' wide.
Looks similar in size to a two row cultivators that were frequently used on corn and pulled behind N-series fords.
Its light weight and cat 1. That alone tells you that you dont need or want an 8000# tractor of 70hp.
   / HP Requirements for Field Cultivator? #5
That field cultivator isn't real heavy so I doubt it will pull hard, depending on soil moisture and hills your 2150 will probably handle it with no problem. It is definitely a tool for ground that is broken and not a primary tool.
I would say it's that wide... here is the pic from the rear. I agree that it's light duty, and - for what I will use it for - it probably will work just fine. It's not heavy enough to sink too low, and I can set the depth with my three point anyway. I mainly am wanting something to keep the soil tilled for a year or two before I buy a tiller, stuff that's already been broken with a tiller twice. I have a single-row six-tooth cultivator which worked pretty well last Spring, but I am welding on some pieces and removing tines to turn it into a disc-hiller, and it wasn't wide enough to cut out my tire tracks anyway, so something like this would make for an easier, dedicated harrowing operation.
Yes, I agree. Not trying to break any new grown, just maintain broken ground from being taken back over.
   / HP Requirements for Field Cultivator? #8
Put a tape measure on it and dont guess.
Either way, try it. If its too much, take the back outside tines off. If still too much, take the front outside tines off. Find what works.
But cultivators pull easy in already worked/planted ground
   / HP Requirements for Field Cultivator? #9
   / HP Requirements for Field Cultivator? #10
Probably work great for pulling rocks to the top for easy picking
2025 JMR 36in Mini Skid Steer Bucket (A55787)
2025 JMR 36in Mini...
2013 Chevrolet Express 2500 Cargo Van (A55788)
2013 Chevrolet...
2014 Ford F-550 XL (A53314)
2014 Ford F-550 XL...
16' Cattle Guard (A53316)
16' Cattle Guard...
2001 International 4700 Dump Truck, VIN # 1HTSCAAM51H379512 (A54865)
2001 International...
1977 Ford F-100 Super Cab Pickup Truck (A55788)
1977 Ford F-100...
