SkogenMe
chuck172 said:You can store the heat and fire the boiler up once a week in the summertime and get all the hot water you need.
Almost sounds too good to be true. You know the old saying, it probably is.
I'm close to buying it though.
I have heated our house for 15 years with a Dumont unit (Boiler + 1,500 gal storage). It is great...house @68 deg on programmable thermostats, fire for 4 hrs/day in January.
Just a note tho' ..part of the too good to be true is if you use it for hot water heat in the summer, your basement is going to be some warm even with an insulated tank. We did that for three years..ended up putting in an electric hot water heater that we used in the summer...then replaced that with a solar system/gas boiler in series. We use the solar in the summer, gas/solar in the winter. We stopped using the hot water coil in the winter because the piping got a little complicated and it isn't "free"...it has a noticable draw on the storage tank temperature.
0.02 worth
