hst boots
   / hst boots #1
oldtommyboy
Etters,Pa.
BX25
Hello everyone,quick question- I made a plate to protect my hst fan and dang if I didnt get the front boot ripped off instead.
Does anyone know of a replacement split boot so I dont have to remove the propeller shaft on this bx25?
Kubota's boot is 2 dollars and some cents but I do know about the pain in the *** procedure to get the shaft out so is there an aftermarket split boot somewhere?
Concerns,ideas,etc.Thankyou
   / hst boots
Wow,163 views and nothing,oh well guess i know where that leaves me !
   / hst boots #3
I don't know about the split boot but welcome to TBN.
   / hst boots #6
Try an internet search. I am guessing no, because a split boot means a spot that woild leak and let crud in.
   / hst boots #7
Welcome to TBN, I would help you if I could, but unfortunately I cannot. I have never seen this come up before on the forum.
James K0UA
   / hst boots #8
How about some Gorilla tape or electrical tape to help until you get it resolved.
   / hst boots #9
You can buy some liquid rubber that will probably make an effective repair. Make sure you clean the seam very well, using whatever the recommended solvent/cleaner is. If you want to, and can find access, you might consider using the equivalent of a tire patch on the inside of the seam as well. This would provide more strength. The liquid rubber cure rate will be a function of temperature, so you may want to do it in a heated garage, or use a hair dryer. Good luck! Let us know how it turns out.
Phil
   / hst boots
I found the boot laying on top my mower deck when I took it off last week,its destroyed,dont know how or when-thinking when I was munching leaves this fall-no clue. I know you used to be able to but them for car cv joints.
Fiqures,I built a plate to protect the fan and I do this somehow.Yep totally destroyed,only about half is left,looks like a animal chewed it up but no way ( in my garage )
Didnt think about just taping up around it,really dont want to tear this apart,got enough things to do with winter coming.
2023 JOHN DEERE 317G SKID STEER (A51242)
2023 JOHN DEERE...
Bef-Co Finish Mower - INOPERABLE/PARTS ONLY (A52128)
Bef-Co Finish...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
KMC KELLEY 3374 PORTABLE PEANUT COMBINE (A51243)
KMC KELLEY 3374...
