HST filter popping
/ HST filter popping #1
mpvoss
Okay I'm at a loss. I have a BX1500 that I changed the HST transmission. I had the old tranny out previously to change the forward/reverse relief valves. I change the transmission, put everything back together. Start the engine and the hst filter starts to leak. I tightened it and then it blows apart. Replaced it and started the motor 5 seconds later the replacement filter pops. Whats the problem?
Thanks for your advice and opinions.
/ HST filter popping #3
The relief valve for the HST charge pump is not set properly or the tranny was assembled incorrectly not allowing the oil to flow through the filter.
Either way do NOT try and run the unit until you get it fixed or you will destroy the new HST.
iDrive TDS-2010H...
International 10ft 8 Way Grader Blade (A64047)
International 10ft...
2018 John Deere Z950M Zero Turn (A63116)
2018 John Deere...
Kubota M7040 Tractor (A61166)
Kubota M7040...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
