HST gear range L-M-H select issue
   / HST gear range L-M-H select issue #11
It won't make them harder to spin while suspended in the air by the FEL, what it will do is make the circumerence of the tires larger which will change the pressure on the drive train when the tires are in contact with the ground and in MFWD. :p
Troy
Ok, just glad to see it's not just me. I try to be patient, but shizzle, I get so frustrated sitting there pushing/pulling/yanking/steppin' on the go pedal etc. trying to get the dang thing going. Kubota really needs to check into this if they're gonna offer this type of tranny.
j
   / HST gear range L-M-H select issue #13
When this happens to me, I just put it back into the gear I took it out of and then try again and it slips right in. Doing it this way has never failed yet.
   / HST gear range L-M-H select issue #14
When my L3430 doesn't want to shift I put it back into the gear I was in and reverse direction slightly before trying it again. 99% of the time it slips right into the gear I need.
I usuall have to do the same thing to shift from 4wd to 2wd.
   / HST gear range L-M-H select issue #15
I just move forward and backward in my seat to shake the tractor a little and it pops right in.
   / HST gear range L-M-H select issue #16
Clutch engage,take foot off brake let tractor roll very little,or turn steering wheel Lor R....works for me.
   / HST gear range L-M-H select issue #17
I feel like a dummy for asking this question, but how can adding air to the front tires while they are raised with the fel make the front tires harder to spin?
When tires spin while raising the front of the tractor while in four wheel drive it is because of axle wind-up. It is because you don't have a good relationship of the axle turns between front and rear axles.
Adding air or letting some out will balance it most of time unless there is a miss match of tire sizes and makes.
   / HST gear range L-M-H select issue #18
I have had this happen a few times.. today's 4 hours I shifted nearly flawlessly everytime...
BUT I have almost 200 hours on mine now..
It was tougher near the 50 and 100 hour marks...
Later,
J
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59904)
2019 INTERNATIONAL...
KBH 25T Tender (A56438)
KBH 25T Tender...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
