HST ? improved over the years
   / HST ? improved over the years #51
JC-jetro said:
Dave, My understanding is that the cylinder block rotates both in case of hyd motor and pump. swash plate angle can be either fixed or variable. Do you disagree with that?
Yes, this is what I stated in post #39 above.
When trying to communicate and understand anything technical, it is
important to understand and agree to the jargon used. Sometimes definitions
are needed as part of the discussion; sometimes we rely on established
unspoken definitons.
On the subject of jerky HST control, all of the HSTs I have operated
have some sort of damper on the GO pedal or pedals. The older tractors
I owned with HST were a bit jerky, more so in higher ranges. This was
due, at least in part, to a worn damper. My new machines have all been
very smooth, and they are not even the more sophisticated HST-plus
or eHydro, or other newer generation HST.
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
