HST Pedal issue (sound familiar ?)
   / HST Pedal issue (sound familiar ?) #1
SGTractor
BRESILLEY (FRANCE)
LS RIO36 HST + David Brown 880 Selectmatic
Hi again,
The tractor is doing rather fine (or rather was....) I did the 50 hours service yesterday, the French importer (honestly a douchbag...) for LS specifies that the transmission oil must be changed as well as the filters, seemed like a waste but I went along with it, I used the old oil for a very old David Brown 880 Selectmatic tractor that had been running "mayonnaise" in its internals :laughing:.
I do have a issue I was hopping the oil change would solve nut it hasn't :confused:, the bloody HST pedal has started being lazy (1 to 2 second lag) when coming back to the center position, it started around 45 hours and hasn't improved a bit with the maintenance.
It only does this when running the engine with a range selected (ie moving) if I play with the pedals in neutral it works just fine....
Now I'm going to try to see if I can fix it by cleaning and lubricating the linkage (the V notch thing included) but in case this isn't the solution has anybody else ever had the issue ?
Cheers from europe
JLG 1255 Telehandler (A52128)
JLG 1255...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
