HST Power Consumption
   / HST Power Consumption #111
My BX may or may not go up my hills. I normally don't open the throttle wide open because it just seems way too fast. I usually run 3/4 to 7/8 throttle, no tach on mine so this is just by ear/feel. I usually have to use low gear to get up the hill.
I'm going on vacation and taught a neighbor kid how to mow my lawn last night. I had him throttle up for the mower and he just yanked it wide open. I had warned him it might not go up the hill in high gear, but it went up just fine.
So...is the relief valve variable with the pressure applied? It would have had max pressure applied last night with max rpm. Yet it didn't open. At slower rpm it opens and the tractor stalls out (engine doesn't pull down at all). What's happening? :confused:
I think this relief valve theory for the HST is bogus. The HST does not have a relief valve in the sense that the hydraulic system of the tractor does for the loader and auxiliary attachments. At low engine RPMs in high range you just weren't generating enough power to drive the tractor up the hill. HST can easily deliver enough power to stall the engine - that is why some tractors have the "stall guard" feature for example, which will back off on forward speed if the engine RPM starts to slow too much due to loading.
To deliver high torque to the drive axles with HST you need to up the engine RPMs and back off on the pedal. It should deliver enough power to creep up the hill even in high range. On the other hand, when flooring the HST foot pedal at low RPMs under load the engine is simply not delivering enough power to move the tractor at the requested speed.
I suspect what is happening is that when one floors the pedal the swash plate on the variable displacement HST drive pump is fully tilted to increase the hydraulic flow to try to increase the output speed, but given limited engine power output and RPM, an increase in flow/displacement in the pump will result in a reduction of hydraulic pressure. The reduced hydraulic pressure is insufficient to drive the output hydraulic motor against the load. The delivered power is not enough to overcome leakage in the variable displacement pump so the output speed drops to zero. Backing off on the pedal will increase the delivered output pressure and you may get some forward motion. Up the engine RPMs and you get more until eventually the engine lugs or stalls due to maximum power being delivered.
The bottom line is, if the HST lugs, back off on the pedal and/or up the RPMs.
   / HST Power Consumption #112
I am not sure,but I think that may be what happens to my Kubota RTV. If going up a hill and it starts to lug down with your foot full on the floor, just reduce throttle and it climbs right on up. It is hydrostatic drive but different from a tractor.
Regarding efficiency, when my BIL with his NH 2030 and I were digging out our old pond and moving the dirt several yards to a spoil pile, my gear drive Yanmar with powershift would slightly out work his tractor. He had to shift from Med to Low range to load the bucket and then shift back to make the long trip. With my gear drive but powershift hydraulic clutch, I could down shift to 1st load up, reverse to turn around then shift up to 3rd all in same range and do my round trips slightly faster due the the powershifter. I don't know if I could have done it with manual syncronized shift with reverser or not. I dont think there is enough difference in pulling power between the two on a CUT to really notice the difference in either fuel economy or power to the wheels. No doubt the hydro does use a bit more fuel but in forward reverse work, it may make up for it in time needed to do the task. I guess we could go on and on, but the bottom line is that the best tool for the job is whatever you are comfortable using. I like hydrostatic for lawnmowers vs straight gear drive. I prefer my gear drive when bushhogging open pastures as I can just set the throttle and go. I will let you know how I like my TLB with 3 range hydro whenever I get home to use it. I think I like the powershift best of all as it combines the ease of shifting to vary the speeds and the efficiency of a gear in power to the wheels. Powershift isnt variable to 0 speed but it does slow enough to ease up on a task slowly and then there is alway the foot throttle that you can vary even more with all without loosing any power via a hydrostatic pump.
   / HST Power Consumption #113
We used to tow with a Tracker before the Matrix, big drop in towing ability. The 5030 only does well once you get moving, you can't drive slow in high, and if you stop on a hill with a big load, you are back to medium until you stop on the downhill to shift back to high.
Its really not that bad, its far better than driving the old Ford 5000 at my buddies farm, you have to start in gear, when loaded starting in road gear is nearly impossible. I used to be able to double clutch so you could start in a lower gear it but its a hand throttle and between the legs floor shifter with a weird pattern, hard to do, and hard to recover if you miss a gear. Not really meant to be shifted.
Tires are cheaper than clutches:D My buddy had a Yaris with a 16' aluminum boat and on the ramp we just revved it to 3k and let the clutch out smoothly. 3 ft of spinning and off we went with no clutch smell. I tow with my Tracker and it does have a short 1st gear so you it starts pretty much like normal. And there's always low range to get to somewhere flat to use high range again.
I'm impressed you 5030 does fine in high range on the hills with a load. I don't think mine would be anywhere near top speed on any type of slope with a hay wagon and in high range.
   / HST Power Consumption #114
It does have a relief valve just like a standard open system. In fact they have 3. 1 for forward, 1 for reverse and 1 for the charge pressure. Some use a shuttle valve with 1 relief for the HP system but they can be a pain when the shuttle messes up. CJ
   / HST Power Consumption #115
Yes there are relief valves, all I meant was that I doubt they are activating and limiting final output drive power in the case being described. Rather with low engine RPMs and full displacement (pedal down) probably there isn't enough power being delivered to overcome normal losses in the HST pump. There can't be high pressure being delivered to the HST drive motor as otherwise the axles would turn. I admit though I am not sure when a HST relief valve would be activated - does anyone on here know?
   / HST Power Consumption #116
I looked into this a bit more thoroughly. Simple enough really. If the tractor stops without stalling out while under heavy load with the pedal down (e.g. hill climbing) then the appropriate forward/reverse relief valve has been activated. Pushing the pedal further merely increases the pump displacement hence flow, diverting more flow through the relief valve and hence delivering less power to the HST motor and the tractor slows. Back off and you are generating maximum torque at maximum efficiency. Up the RPMs and you should be able to deliver a bit more torque out, although inefficiently and with some abuse to the HST if the relief has been activated (but a bit more aggressive ground speed and momentum may help get up that hill). Eventually you have to shift to a lower range which will allow the HST to operate more efficiently at a lower pressure.
So to answer my own question, yes the HST relief valves will kick in if one pushes it hard enough. Could also happen due to shock loading. But it is still possible to stall an HST tractor under heavy load, so the relief pressure must be set near the limit of what the engine can deliver.
   / HST Power Consumption #117
You are not reading it wrong but you are interpreting it wrong. PTO HP is determined with the tractor sitting still running a dynomometer off the PTO shaft. No power is transmitted through the transmission - except for the step down gear ratio that brings it down from engine speed to 540 rpm PTO. The difference you see between bare engine power and PTO power goes to parasitic loads. The hydro requires an additional hydraulic pump for its controls and it is running anytime the engine is running. In my Kubota there is one way to stop this pump - step on the clutch which does stop the charge pump. Only problem is if you step on the clutch you also stop the PTO.
I think the difference between maximum power and PTO power has lot to do with the power characteristic of the engine. In example maximum power is produced at 3000 rpm but power at PTO speed is produced at 2150 rpm. As a rule PTO speed is set little past the maximum torque the engine produces. reason being maximum torque is a point of the best specific fuel consumption. PTO power is power delivered on the output shaft therefore it is the engine power minus gear loses.
   / HST Power Consumption #118
There are those who argue that maximum torque rpm equals best fuel economy is only the case when an engine is on a dyno and not in a real world situation, and that lower rpm below torque peak will usually result in a fuel savings. To be honest, I have never seen what a torque curve looks like for a small diesel engine like my Yanmar and I am now curious enough to wonder what it's like.
   / HST Power Consumption #119
Excellent post and I agree with you, especially the last line. To owners like me, who almost never run at a constant speed, HST is well worth the small amount of extra power consumption. I was out mowing my smallest patch of yard last night, it's the one that has a lot of trees and obstructions so I need to change speed and direction constantly and I HATE the thought of having to do all the shifting and clutching a gear tractor would require.
I have 26hp "Greenfield" lawn tractor that uses a belt/pulley/ friction clutch transmission that is as responsive as a hydrostatic, more efficient and mechanically simple.
I use that for my lawn yards and a geared CUT for my larger horse pastures.
   / HST Power Consumption #120
I have never seen the name "Greenfield" as applied to power lawn equipment. Hmm, maybe somebody needs to start a new thread about the power consumption of a belt/pully friction clutch transmission vs. a hydro....
1837 (A58374)
1837 (A58374)
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
2016 FREIGHTLINER CASCADIA SLEEPER (A58018)
2016 FREIGHTLINER...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
LOT: Flaring Tool Sets, Pipe Cutters, Brake Line Bender (A59076)
LOT: Flaring Tool...
