Humidity in crawl space
   / Humidity in crawl space #11
In addition to whatever else you do I would install a radon pump. This will suck moisture right from the ground before it reaches the crawlspace.
   / Humidity in crawl space #12
If you are in an area where Radon can be a problem, test for it. They sell kits for it everywhere. I took steps with my house thinking I'd have a problem in a heavy limestone area - but several tests show no issue. You can install a vent pump, What I did, based on some expert advice, is lay some pvc inch pipes with holes drilled in them around the rough center of the crawlspace UNDER the sealed plastic. The pipes all connect to a vertical pvc pipe that goes up through the house inside a wall and out the roof. Any gases are vented. I found I didn't have any real issues but had already installed the system. (I capped it for the tests.)
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
2002 International 9200i Truck (A55218)
2002 International...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
