husky 350
   / husky 350 #1
npfitz
to upgrade to a pro-saw? if so does air filter need to change or would be worth
doing. if so what needs be replaced
   / husky 350 #5
Not sure what you are asking:confused2: Could you be more specific???
Are you trying to make your 350 a "pro" saw by just chainging air-filters???? Not going to happen if that is what you are asking,
   / husky 350 #6
350 is a plastic saw with bolt on 52cc cylinder. I pass on them like new for $100 to $175 all the time.
Decent home owner saw.
You can bolt on a 346xp 50cc topend on a 350 and have a plastic crankcased 346 power. You can also bolt on a 357 carb on one too. Did it one day for chits and giggles.
   / husky 350 #7
Let me get this straight.
If you have a husky 359, swap top end to 346xp and use 357 carb, it will make the 350 a decent pro saw ? :confused2:
   / husky 350 #8
Totally wrong :laughing::confused2::confused:
   / husky 350 #9
i would buy every huqvarna 350 in like new condition you can find in the $100 dollar range. used and abused on ebay in the $250 plus range. these were a great saw. the new models are rebadged poulans called ranchers. the 350 was and still is a great saw. i also have a 346 xp.
   / husky 350 #10
The 450 clamshell saw is the replacement of the 350 is not a poulan saw. :confused2:
The 455 plastic saw clamshell type replaced the 55 rancher.
None of them were Poulans.
Only the smaller husky 235 is a rebaged poulan now days that I have seen and in the past it was husky 36 41 136 141.
On the 350 52cc plastic saw I ran the other day to compare to a 50cc 346, no comparison. 350 would make a great homeowner saw if you can keep the muffler on them tight and keep from melting a hole through the plastic crankcase oil tank. Send me the $$$ and I will start picking them up for you for cost of gas and shipping.
So please do tell me all these new models that are rebadged poulans and called ranchers.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
Deere 317G (A50120)
Deere 317G (A50120)
2003 Doyle Semi Horse Trailer (TITLE) (A50774)
2003 Doyle Semi...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2024 New Holland T8.410 MFWD Tractor (A52748)
2024 New Holland...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
