Husky YTH 1542 oil drain valve won’t open
   / Husky YTH 1542 oil drain valve won’t open #1
fruitcakesa
Veteran Member
CavendishVT
M6040 JD 450C
Like the title says when I insert a screw driver or use a hex wrench on the drain “bolt “, the soft plastic just deforms and doesn’t move. The manual says to push and turn the entire valve CC to open but it feels tightly bolted to the engine.
Any advice? Thanks
   / Husky YTH 1542 oil drain valve won’t open #2
Is this the style of drain where you attach a short piece of hose and then turn the plastic exterior counter clockwise a short distance and the pull a short distance? If you clean the assembly well you should see an “L” shaped slot in the plastic sleeve. There would be a pin in the slot that is what guides the sleeve.
False alarm, the hex reference was for an Allen “hex” wrench. Dohh!
All is well, oil and filter changed.
  • Good Post
Reactions: JJT
2008 Cadillac DTS Sedan (A53117)
2008 Cadillac DTS...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
Valvoline 80//90 Gear Oil (A53117)
Valvoline 80//90...
Metal Peacock Lawn Art (A51694)
Metal Peacock Lawn...
