Husqvarna 455 Rancher
   / Husqvarna 455 Rancher #21
Thanks, i didn't know it was available from the factory with a 24. My dealer told me to go no larger than 20...... but in reality, how often would i use the whole length of the 24??!! I'd like to have it available when needed. I too have a smaller saw, a Stihl MS 210 w/ 16" bar. It was a great little saw for me, but i suspect i've burned up the rings. I'm contemplating replacing it with a Husky 350 or 346xp. Anyone have recommendations on a smaller saw for me?
   / Husqvarna 455 Rancher #22
I have a Stihl MS 290 Farmboss with a 20" bar for the big logs but it will wear you out over an extended period. Great saw for the money. For a smaller lightweight saw I highly recommend the Echo CS-340. I wanted a saw I could "one-hand" and this saw with its top handle and throttle control fit the bill. I know that some bad rap the Echo's compared to the Stihl's and Husky's but I have used this saw on a variety of woods from locust( a step down from steel:) ) to pine and from cutting 20" diameter logs to general limbing and it has never failed me. Lightweight, rugged, with plenty of power I would not hesitate to recommend it to anyone. I run a 16" bar on it but you can run smaller.
   / Husqvarna 455 Rancher #23
I've got a 346XP (along with a 262XP, and a 385XP) and love it. It's small, light, yet still packs a real punch.
   / Husqvarna 455 Rancher #24
I have a 2yo Stihl MS310 and it has been a great saw so far, no problems and with a sharp chain it will cut so easily it's almost fun to use!! At 13lbs (w/o bar), it can get a bit heavy after extended use and isn't really good for limbing. For that I am thinking of something smaller, maybe an echo or another Stihl, that way I can use the same fuel/oil mix...
cheers,
bigballer
Not such a surprise to hear you recommend the Echo. The Ace store I've been looking in have as many Echo's as Husy. Will probably look at the Stihl tomorrow before I make a decision.
   / Husqvarna 455 Rancher #27
In my perhaps simplistic view of saws, I first bucket them into weight classes. They tend to fall in the 10-11lb range where the 346XP lands, then 12-13lbs where the Stihl 310 and Husky 455 land, then 15-16lbs when you get into the high end stuff. My personal approach has been to pick the weight class I want, then select the most powerful saw in that class. When you use a saw for any extended period of time, the power to weight ratio really matters. The 346XP is a good example. It has the same power as the 455, yet is in the next lighter weight class (about 2 lbs lighter than the 455). In the 12-13lb class, the new 362XP looks nice at just about the same weight as the 455, but around 30% more power.
   / Husqvarna 455 Rancher #28
cheers,
bigballer
Same here (ms310). It is my main bucking saw. Rest of my stable is:
Husky 51 (rescued from a pawn shop) - great small limb/trim and small bucking saw.
Stihl 041 w/24" bar - falling and bucking large stuff.
It is amazing how much faster and lighter saws have gotten over the past 20 years!
Chains. Get them in a saw shop. They make them up from rolls of chain. There is no need to find a 'husky' chain for a 'husky' saw.
Harry K
   / Husqvarna 455 Rancher #29
CharlieTR said:
Husqvarna is a good as they get!
I have the 350 and no complaints. I do wish chains and such were easier to find though.
Go to 18" Timber Champ from Baileys-online.com for your bars and chains. I just bought two 18" Carlton bars with chipper chains for $48.85 delivered from CA. to Ma. You can't beat that. As for the 455 I really can't say. It replaced the 55 Rancher which I own two of and love them both. I bought one of them brand new a few years ago and bought the other one used last year for $100.00. I took on a tree job recently to clear my neighbors property. My brother and I have been pushing those 55's real hard and they keep right on kicking. I use my Husky 262XP for the really big stuff.
Took a quick look at the Stihl 310 Friday evening, got there right before the place closed. So now I'm interested in it also. But then I walked into a second ACE and they had the Rancher for like $349, best price I've seen by $15. I was very tempted, but I really want to look at that Stihl again, even though it would be like $60 more.
After all this, I found one of those super stores on the web that advertise the Rancher for like $330 with the 20 inch bar, and they through in shipping, a t-shirt, second chain, and couple gallons of mix. Now it really has my interest. It is coming in at like $80 under the Stihl.
But then I tried Ebay. Wow! A huge selection of Stihl saws can be found there. There is something like 200 on auction. The other makes have just a few.
You know what I'll be doing this coming week.
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
CFG Industrial MX20R (A50121)
CFG Industrial...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
JD Z225 ZTR Mower (A50121)
JD Z225 ZTR Mower...
Takeuchi TL150 (A50120)
Takeuchi TL150...
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
