Husqvarna lawn tractor issue
   / Husqvarna lawn tractor issue #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
A buddy of mine was talking to me about a issue with his lawn tractor so I thought I would post the question.
He has a Husqvarna lawn tractor from Lowes (48" cut with a non pro Kohler motor).
When he cuts a bank that slopes one direction it stalls and dies. if he cuts the same bank the opponent way it is fine.
He has taken the tractor to the dealer and they replaced both the carb and the fuel pump. It still has the same problem. The dealer pretty much said they give up.
Anyway I mentioned the gas tank vent and he found a hose that connects from the neck of the tank and runs to either the airbag or the carb he believes (I don't have a photo). I told him to disconnect this line at the tank and see if it runs. he did and it ran perfect. Hooked it back up and found that fuel drains into the line and that is when it chokes itself out.
We tried looking up the model parts diagram online and the funny thing is it did not even show the line nor the connection on the tank??? Go figure. Any idea what this line would be (Gas tank vent, some kind of carb vent perhaps) Without seeing it I can really guess as I know next to nothing about these mowers. Any thoughts on the proper repair???
He needs the mower and I am a bit of a ways away but think it would help if I can get it here and I take it apart to figure it out but would like to know if there is something he could do at his house to repair it.
Can you guys figure this one out???
THANKS
   / Husqvarna lawn tractor issue #2
Newer compliant mowers have an internal venting system, so rather than a venting cap- vapors are vented into the carb. Fuel shouldn't be in the line- so the slope is too severe or the tank is overfilled and the line fills with fuel when it is on the downward side as you suspect. A wise man wouldn't probably tell you how to alter an emission devise on a public forum. If you feel the machine is being used as designed , contact Husqvarna first. It's called progress I guess. Remember the good old days when a venting cap was good enough?
   / Husqvarna lawn tractor issue #3
the popping and rough engine run i also have and complained and it is brand new and the dealer didn't want to deal with it - blamed fuel - have used brand new fuel in 4 tanks and all the same issue. i am very p*ssed.
never buy another husqvarna again.
also use the fuel in 4 other machines here and no issues at all. so not a fuel issue.
   / Husqvarna lawn tractor issue #4
Because Husqvarna made the engine which is the problem, right? :rolleyes:
   / Husqvarna lawn tractor issue #5
no they do not offer support for what they sell when it starts at about 3 hrs - that is as close to a brand new machine. WTF!!!!
THANKS - I am thinking it is also a venting issue. Think we are going to experiment with a vented cap and see if that helps clear up the problem. Kind of of pain to only be able to mow a hill in one direction......
   / Husqvarna lawn tractor issue #8
Which specific model is it?
   / Husqvarna lawn tractor issue #9
Not sure what model you're referring to, but I do not have that problem with mine. 2 years old, 16 (I believe) hrs on it.
2008 International School Bus Hood | OEM Quality Replacement | Fits IC Bus and More (A46877)
2008 International...
Club Car 1700 (A44391)
2023 BAUMALIGHT MS1160 MULCHING HEAD (A43004)
2023 BAUMALIGHT...
2002 Ford Ranger Ext. Cab Pickup Truck (A44572)
2002 Ford Ranger...
2016 WESTERN STAR 5700 SLEEPER (A43004)
2016 WESTERN STAR...
Ryobi Sliding Compound Miter Saw (A44391)
Ryobi Sliding...
