Husqvarna TS 354d Kohler KT740 Won’t Turn Over
   / Husqvarna TS 354d Kohler KT740 Won’t Turn Over
That sounds like the solenoid is engaging and the starter is not getting the required voltage or amps to engage the starter.
Could be a bad starter, low +12V wire going to the starter, a corroded or bad connection at the starter itself.
Next step is to verify the actual voltage at the starter when the key is moved to the start position.
I hope you post the final fix once you find it.
I hadn’t considered a bad starter, but I guess I should because the previous owner caused the solenoid to melt. I can take the starter off my old mower and try it.
   / Husqvarna TS 354d Kohler KT740 Won’t Turn Over #12
I am not familiar with your machine, but most solenoids can be disassembled. You maybe able to just rotate the contact bolts that the solenoid plate contacts and then it will work again.
Well with a new solenoid it turns over with the key.
The original solenoid on this engine was melted and I switched to one from my old mower.
The one from my old mower was from 2013 so it was likely on its last leg.
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A58375)
UNUSED SET OF...
2005 Suzuki King Quad 700 Fourwheeler (A57453)
2005 Suzuki King...
5' ROTARY MOWER (A58375)
5' ROTARY MOWER...
2019 Chevy Cruze Sedan (A56859)
2019 Chevy Cruze...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58216)
2013 TEXAS PRIDE...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58216)
2004 VE...
