kennyd
Advertiser
OK so here is an open center solenoid:
https://www.surpluscenter.com/item.asp?item=9-6137&catname=hydraulic
They calling this a motor spool. What specifically makes this OC valve a motor spool rather than just ordinary OC?
And here is one they call reversible.
https://www.surpluscenter.com/item.asp?item=9-7312&catname=hydraulic
What makes it reversible? Isnt the other valve also reversible because it is a 3 position directional? I guess I should read the spec on this valve because it doesnt seem to be a normal OC valve, but something special.
The first valve is for motors because both work ports are connected to the tank in neutral. That would be almost useless to operate a DA cylinder. It can reverse the motor also depending on which solenoid is powered.
The second valve has no neutral position- not what you want.
Have you thought about using the PTO to power the trencher through a gearbox? Seems like you'd have more power than dealing with the losses of a hydraulic motor, and it may be cheaper also.
