Hyd Gurus pls help - Backhoe hookup (3 hoses) how to plug ?
   / Hyd Gurus pls help - Backhoe hookup (3 hoses) how to plug ? #11
My mistake, I forgot your loader valve has no PB only tank. If your BH valve's tank port can handle full pressure you can convert it to non PB and plumb the tank into the next valve in the chain. If it can't, I'd figure out how to run a line directly into your tank.
Ok good Ill try what I drawn to prevent damage to the tank side from the PB power by running the tank hose to return
Ill try that by adding a QD under the remote (after it) for the BH tank line
The BH PB hose to the return too via the remote return port.
By removing the PB adapter, the flow can only go to tank side BUT also tank outlets of the last valve stack thus maybe possible damage by reverse flow ?
Wont take chance ! Thanks Ill let you know if it works in a few days I need to wait for parts.
Bye, Jason :)
cummins generator (A56857)
cummins generator...
2011 Kenworth T7 Series (A55973)
2011 Kenworth T7...
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
49205 (A55788)
49205 (A55788)
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
