Hydralic Fluid and Rubber Matts
   / Hydralic Fluid and Rubber Matts #1
colestin
Ashland, Oregon
Branson 3510
Okay, I have a leak. It's at one of the quick-connects with the loader control lever. I think I will need to remove most of the other connectors in order to tighten this one, so I won't be doing it right away. I try to keep a tin lid on the mat to protect it, but I bush-hogged the tin lid... anyway, the mat has sorta... swollen... in that area.
Should I just hit it with de-greaser and find a new tin lid until I fix the leak?
   / Hydralic Fluid and Rubber Matts #2
On my 2810 mine did the same thing.
   / Hydralic Fluid and Rubber Matts #3
More than anything else, the fluid will make the mat slick and cause you to slip going on and off the tractor, so be careful.
Many times, the leak is caused by an 'O' ring in the quick connect that is pinched or worn. This is a two minute fix, to pull out the old one and insert a new one. O rings are available at most hardware stores....
I had heard that the O-ring could not be replaced (you are right about the dinged-up o-ring). My dealer sent me a new quick connect, and I installed it. Torqued it as tight as I dared with my inadequate tools, and now it leaks from the threads. Next time I will replace the ring, now that I know that is possible. Thanks!
Yep! I doped the threads pretty good -- I thought. Maybe not good enough.
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
2024 KMC 7406 (A53084)
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
