3-Point Hitch Hydraulic coupling need for NH 3045
   / Hydraulic coupling need for NH 3045 #1
donjal
Hayward,Wi
Int444,Int2500A
I have a NH 3045 tractor. I would like to hook a 3pt woodsplitter to it. The woodsplitter has its own forward and backward valve. It is suggested that I have the splitter return fluid directed through the fill plug opening on the hydraulic reservoir of the tractor. I am looking for a female quick coupling that would screw into the fill opening. Any sources for such a coupling?? The local Kabota dealer said they mounted one on a Kabota, but can't remember where they got it. Thanks for any help. DonJ
   / Hydraulic coupling need for NH 3045 #2
Don, you need to give us more info. Do you have a loader? Is it NH? Do you have factory hydraulic remotes? Any answer needs that info. The way you are describing hooking up your splitter is a recipe for disaster. You can use a factory remote or the FEL quick attach fittings, but tapping into your hydraulic system and returning directly to the reservoir is less than satisfactory.
Also, you've broken a TBN rule by posting the same question in two forums. You should always post your question once and then post a link to the original post in any other thread.
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2014 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2014 Ford F-150...
24628 (A55853)
24628 (A55853)
2016 Club Car Carryall 710 Electric Utility Cart (A55851)
2016 Club Car...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
