Hydraulic Curcuit Tester
   / Hydraulic Curcuit Tester #11
Thanks DFB,
I have the TM for my tractor on order...guess I'll wait and read it.
Larry
From the link DFB provided http://www.hydracheck.com/jfm.html This page shows an in line connector that can be installed and all you have to do is screw the gauge in whenever you want to check it. They list several of these connectors and I guess the trick is making sure you get the right size and style for your application.
Ernie
"You can plainly see that the Alamo was never built by a military people for a fortress."
Green Jameson, Jan 1836 (in a letter to Sam Houston)<P ID="edit"><FONT SIZE=-1>Edited by ERNIEB on 1/12/01 05:36 PM.</FONT></P>
   / Hydraulic Curcuit Tester #13
MarkCG & Larry - Remember that our tractors have "open center" hydraulics, so the whole system is just one circuit - therefore, if you put a gauge in it almost anywhere, it will read the pressure (resistance to flow) generated by using any valve in the circuit.
The handiest place (for me, anyway) was on the loader valve block, especially since I almost never remove the loader. (If you use this location to tap into the system, you just have to mount the gauge on a part of the loader that also detaches with the loader. No big deal, unless you really need the gauge when the loader isn't in place, which isn't too likely.) I put a rigid tee directly on the loader valve block "pressure in" port, then re-attached the "pressure in" hose to the inline port on the tee. On the top port of the tee, I put a flow restrictor bushing, followed by the hose to the gauge. The purpose of the flow restrictor bushing is to keep all the fluid from being shot up into the air instantly if the gauge or the line to it burst - I'd at least like to have time to shut the tractor off before it damaged anything.
Again, remembering the "open center" design of the hydraulic system, even though my gauge is mounted to the loader (you can see pictures of it in my "L4310 Enhancements" thread in the Tractor Customization section), it still registers the pressure required to lift implements by the 3-point hitch, for example, or even the remote cylinders on the hitch itself or gauge wheel implements.
MarkC
MarkC, Looked up your picutures and comments in your "L4310 Enhancements". Do you have a close up photo of the gauge? I'd like to see how you have it installed. I have a pretty good idea from your discription, but I still would like to see it.
I would also be interested in your overall impressions, it's usefullness. I should tell you I'm more interested in putting one on my dump truck , but maybe the tractor too.
Ernie
"It will be appalling to you to learn, and see herewith inclosed our alarming weakness"
James C. Neill, Alamo commander Jan. 1836
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
