Hydraulic Cylinder Check Valves
   / Hydraulic Cylinder Check Valves #11
</font><font color="blue" class="small">( If you only want to lock the cylinder from drifting down you need only a single pilot operated check. )</font>
Since on a double acting cylinder either port on the cylinder can be the exhaust port, you need a "double" pilot operated check valve to make sure you get no drift down.
The link to the earlier thread that I gave explains it all, in much better detail that I can.
   / Hydraulic Cylinder Check Valves #12
If you lock the cylinder both direction ( in and out) yes you do need a double pilot operated check valve. If you only want to stop one direction (like in or out ) you only need a single pilot operated check. Most lift system only have one check because you want the load not go down.
   / Hydraulic Cylinder Check Valves #13
In the case of using my boxblade, I push just as much as I pull with it so I want it locked on both sides of the cylinder. I have the Prince double-pilotted valve on my toplink, have used it under commercial use, haven't had the slightest problem with cracking pressure nor leakdowns. It stays where I set it every time and have probably used it close to 300 hours now.
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Jack Daniels Wall Art (A55853)
Jack Daniels Wall...
