Hydraulic cylinder repair, welded
   / Hydraulic cylinder repair, welded #11
Considering how pitted your rod is, if it was me, instead of attempting to rebuild the cylinder (the pitted rod will quickly destroy the seals), I'd replace the entire cylinder or take it to a competent hydraulic shop like Motion Industries and have them evaluate it. That pitted rod will soon compromise any new seals.
I believe a new cylinder is required and they aren't all that costly either.
   / Hydraulic cylinder repair, welded #12
Totally agree once the rod is that pitted, rebuilding usually turns into a short-term fix at best. In my case, I managed to find hydraulic cylinder for sale for a fair price. Truth be told, guys, it is worth it.
   / Hydraulic cylinder repair, welded #13
On that older low pressure system cleaning up the bore and rod with emery cloth and light honing is a good way to go with a minimal investment. If it bothers to much after that then it would be time to investigate new cylinders of the proper stroke.
   / Hydraulic cylinder repair, welded #15
If it were mine, I'd test it for snags with a nylon rag or open palm. Knock any sharps off with a 2" disk then use a surface conditioning belt to buff it up. Internal pits might wick out a minute amount of fluid, but shouldn't cut up the seals.
   / Hydraulic cylinder repair, welded #16
Had that issue recently but not with a cylinder but with a Redding T7 handloading press. The ram had a 'divot' in it and it's imperative the ram travels in the base casting smoothly, without resistance. Bought it use, not new because new, the press is crazy priced and I believe the divot was caused by rough handling in transit so I carefully removed the high spots on it with progressively finer crocus cloth ending up at 800 grit and put it back together. That eliminated the proud metal and all is good now.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
