Leejohn
Elite Member
JJ said it takes a 2" bore X 30" 4.9 sec to go out, would 2 cyl. take 9.8 sec or does that change being 2 Cyl? Are you using 2 cyl. for the lift?
a 2 in bore, and 1.125 shaft, at 5 GPM, would have an extend speed of 6.1 ipsx30 = 4.9 sec
-----------------------------------------------------retract speed of 9 ipsx30 = 3.3 sec
__________________
Push force on that cylinder would be 7,854 lbs
pull force---------------------------5,369
push at a 45 degree angle----------5,554
pull--------------------------------3,796
all the above data , figured at 2500 psi, and 5 GPM
The B7100's hydraulic system is 1700 PSI, and 3 GPM,
