Hydraulic Float Question
   / Hydraulic Float Question #11
Now I see said the blind man. I missed that SA cyl.
Like AKKAMAAN said, plug one port.
All good advice. The owners manual for the rake states nothing in reference to adding anything other than a second hose.
The hyd cylinder has the place for that second hose and the manual says remove the vent plug and install the second hose ... so I am assuming this allows the cylinder to "self float" ??
   / Hydraulic Float Question #13
I can't help with your plumbing problems, can only point out that my rear remotes have float, you mentioned you were not sure if yours was capable. Mine is on JD 4310 with 3scv off the loader valve.
But that raises a question to myself, if my HTL has a check valve would float work on a cylinder like that? not that I can think now of a use I would need HTL to float.
JB.
   / Hydraulic Float Question #14
When you release the valve handle, and go to neutral, the cyl is locked and fluid is blocked. In order to float, the fluid has to be free to move from cyl to tank, and it can do that through the valve I posted.
If that is an SA cyl, the hose they are talking about is just a vent hose. It could also be a DA cyl and they are not using fluid in the rod side of the piston.
   / Hydraulic Float Question #15
JB.
The check valves allows the cyl to hold. You need pressure to relieve the check. Float would not work with a checked valve.
   / Hydraulic Float Question #16
Yes the 2nd hose definition is why the question ... I like the valve ... has me questioning things!!
I think they are saying that by adding the "2nd hose" you turn the cylinder into a DA cylinder and you have to adjust it manually with your non-float valve. You can't turn a non-float system into a float one by adding only a 2nd hose, but you can make the cylinder adjustable in a "non-float" way. That's my take on what they mean. They are saying that non-float, but adjustable via the 2nd hose is better than no adjustment at all.
Of course, if you want to add a 2nd hose and a valve that tees into the pressure side, you could open that valve and allow the cylinder to float while in use and then close the valve to operate the cylinder in the transport position.
Got it ... I believe the float valve mentioned would be a good idea.
1649 (A58375)
1649 (A58375)
1643 (A58375)
1643 (A58375)
DOOSAN G25KW GENERATOR (A58216)
DOOSAN G25KW...
40' Sea Container (A55272)
40' Sea Container...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
