Hydraulic fluid color is yellow?---new to tractors.
   / Hydraulic fluid color is yellow?---new to tractors.
Ivan49--being new to tractors and hydraulics, the 4 main hoses from the controller to the frontend loader look bad to me. One of the hoses had already been replaced but its quick disconnect coupler is dripping fluid---about 8 drops or so during the time it takes to cut my back field. The other 3 hoses look brittle and the outside of the hoses are cracked and split on the end that screws into the hard lines on the frontend loader. In the attached picture you can see what I'm talking about. I'm guessing replacing the hoses and couplers may be expensive?
   / Hydraulic fluid color is yellow?---new to tractors. #12
Yes you are correct to replace them as they have dry rot. Being on the hyd system any time a hose breaks something falls and someone gets a bath. Oil is bad to get off your glasses. You are right it may be expensive but your safety means more than the cost
   / Hydraulic fluid color is yellow?---new to tractors. #13
The lowest cost hose option I have found is buying them from Agri Supply. They are so low cost I have bought one of every size and keep them on hand if needed.
Yes, Ivan49---dry rotted---that's a good description. And I certainly don't need a hydraulic fluid bath or having to deal with oil coated glasses---so replacing those hoses ASAP will be the number one priority this fall/winter.
Thanks for the tip about Agri Supply, johneic.
2025 GIYI GY-PG72C 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A56857)
2025 GIYI GY-PG72C...
207274 (A52708)
207274 (A52708)
New/Unused CFG Industrial XZ20R Mini Excavator (A57453)
New/Unused CFG...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2019 JLG 6042 TELESCOPIC FORKLIFT (A52709)
2019 JLG 6042...
(10) 20' HEAVY DUTY INSULATED PANELS (A58376)
(10) 20' HEAVY...
