Hydraulic fluid for log splitter
/ Hydraulic fluid for log splitter #1
Foghorn
Lake Anna, VA
Kubota 2910
I just bought a Timberwolf 3pt log splitter /forums/images/graemlins/smile.gif. It calls for AW-46. I called the Kubota dealer and they want to sell me UDT. When I asked him what weight UDT was he couldn't answer me but said that's what they but in their logsplitters. Does anyone know what weight UDT or Super UDT is? If it is 46 weight would this be better than the hydraulic fluid TSC sells?
Thanks - Foghorn
/ Hydraulic fluid for log splitter #2
AW46 Oil definition.
Anti-wear Primary recommendation for hydraulic fluids. Must be products with -AW46 Oil virgin oils with a high viscosity index of at least 95. Containing anti- wear, oxidation, rust and foam inhibitors. Oils must meet ASTM D-943 test of at least 2000 hours and generally conform to Cincinnati Milicron P-68 and P-70 specifications.
The owners of log splitter (Wood Splitters) I have been around used the hydraulic oil they purchased at Tractor Supply. Any hydraulic oil that meets or exceeds the ASTM D-943 test spec will suffice.
/ Hydraulic fluid for log splitter #3
UDT, SUDT, UTF are all specced as a hyd fluid. My NH tractors use UTF in their power steering and hyd systems. In my tractors with seperate sumps my manual says i can use 'plain hyd oil' which i take to mean aw32/46 or i can use utf.. Since they cost the same.. I always use UTF...
Soundguy
Thanks guys. I guess I'd still like to know what weight UDT or SUDT is since the manufacture states only AW46 and not AW32.
/ Hydraulic fluid for log splitter #5
Find somebody with an HST tractor and talk them out of the hydraulic oil when they make the change. The last time I changed mine it looked like brand new. My neighbor was happy to use it for his splitter and the price was right to him, FREE!
/ Hydraulic fluid for log splitter #6
Aw46 is thicker than aw 32.. But .. besides knowing what viscosity UDT / UTF is.. you need to know what viscosity the 32/46 are. If they are straight viscosity oils with no heat index modifiers... you could do a simple test with a viscosity gauge that you can pick up cheap at a pain store... or do a somewhat scientific test using a pipette and timer, measuring leakdown on the oils and thus find a similar viscosity oil.. etc.
Soundguy
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A59230)
2008 Featherlite...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
(1) 30"X7' ADS DRAIN PIPE (A60432)
(1) 30"X7' ADS...
UNUSED FUTURE EXCAVATOR THUMB MOUNTING PLATE SET (A60432)
UNUSED FUTURE...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2016 FREIGHTLINER...
