Hydraulic help with 3rd remote on a Kioti CK35hst
   / Hydraulic help with 3rd remote on a Kioti CK35hst #1
Tractor Tom
New Brunswick, Canada
Kioti CK35 H
I just ordered a new CK35HST FEL with a front mount plow and rear mount snow blower. 1 remote runs the plow angle. 2nd remote runs the blower chute turn. 3rd remote is the problem, my dealer tells me this tractor can only have 2 remotes. I want a third remote to operate the blower chute tilt, up and down. Dealer says it can only be done with an electric hyd. Type set up?? At about $700. There must be an economical way to add a third remote to this tractor?? Thanks for the help
   / Hydraulic help with 3rd remote on a Kioti CK35hst #2
Very sure.
Do you have a hyd block and a line going back to the 3pt?
Seems to me you could run as many remotes as you want, lever or solenoid operated.
Not as standard, the dealer is adding the rear remotes, the block as you call it is the unit that has 4 plug in's?? or 2 remotes as the dealer called them?? I'm not a hydraulic guy at ALL as you can see. I just simply want to add 1 more block or remote. The Hydraulic pump system is listed as gear - tandem, flow rate is 12.7gal/min if that helps. Thanks
   / Hydraulic help with 3rd remote on a Kioti CK35hst #4
He is probably talking about factory remotes.
If your tractor is open center hyds, you can add a single of a bank of valves for less than the factory remotes.
I am not sure of the tractor, but here is what one of the TBN members did.
I would recommend a set of three remotes with float on two of them.
The valve monoblock should have PB to feed the 2pt.
You would interrupt the PB line going to the 2pt and insert the three spool remote.
The PB from the new valve would go to the 3pt.
The Out hose would go to a return ling to tank.
The Pb hose from the hyd block would go to the IN port on the remote.
You can get a three spool stacked valve from Surplus like this.
3 SPOOL SV VALVE OPEN CENTER W/POWER BEYOND
Item Number: 9SV-3-Y
POWER BEYOND OUTLET SECTIONQty: 1
SAE8 RELIEF INLET SECTIONQty: 1
3 SECTION TIE ROD KITQty: 1
SVW1DD1 (DA CYL SPOOL W/DETENTED FLOAT POSITION)Qty: 1
SVW1BB1 (DA CYL SPOOL 3 POSITION DETENT)Qty: 1
4 In Stock
$383.90
If you only want a single valve, then look at this valve.
1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
JOHN DEERE 8345RT TWIN TRACK ROW CROP TRACTOR (A54756)
JOHN DEERE 8345RT...
New JMR 66" Skidloader Grapple (A50775)
New JMR 66"...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A54757)
UNUSED FUTURE MINI...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
1995 BMW 318ic Convertible (A55758)
1995 BMW 318ic...
