Hydraulic hose hook-up
   / Hydraulic hose hook-up #11
If it is NPT you are loosening, it is not a good idea, as they will start leaking because the threads are deformed after repeated loosing and tightening.
   / Hydraulic hose hook-up #12
I just got a F-coupler end and put a small valve on it. When I take the loader off I just plug it in and when I hookup I just bleed off the pressure. Mine only gets pressure on one system. If I remember right I plug into the white marked line.
   / Hydraulic hose hook-up #13
Leejohn, I like that idea so much I plan to use it too. I think I'll add a hose connected to a container. :thumbsup:
2019 John Deere 1025R 24HP 4WD Loader Utility Tractor (A55973)
2019 John Deere...
TANK MANIFOLD (A58214)
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
1296 (A58374)
1296 (A58374)
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A58018)
2020 FREIGHTLINER...
