hydraulic hose replacement
/ hydraulic hose replacement #1
jpat34721
Sonoma County (California Wine Country)
MF 1260
I need to replace the hydraulic hoses on a MF-1246 FEL. These are the flexible hoses which go to the joystick valve. I've never done any hydraulic work before. What is the procedure? Do I need to relieve the pressure first somehow? After replacement how do I bleed the system? Any hints would be greatly appreciated.
Jeff
/ hydraulic hose replacement #2
Turn Machine off. Lower loader so no pressure. Unscrew Hose. Take it to your local hose shop, Napa or one of our online sponsors. They can make they any length. Super Simple.
/ hydraulic hose replacement #3
G'day as racerboy said lower to the ground turn engine off and operate joystick in all directions until no movement then take the hose off, to bleed the system just cycle it through it's full range eg right up/down, curl/tilt three or four times and the system will bleed itself
Jon
/ hydraulic hose replacement #4
...and then check the sump to add any makup oil needed to bring back up to proper level.
soundguy
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
Rotary SPOA9-200 Automotive Lift (A59230)
Rotary SPOA9-200...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
