Hydraulic joystick - would this work?
   / Hydraulic joystick - would this work?
The BX23 has two quick connects located on the back that the backhoe hydraulics hook up to - I assume that one of them is the pressure feed and the other is the pressure return. When the backhoe unit is removed from the tractor you take the hose that hangs out and plug it into the other QD to form a loop and the 3pt works properly in this configuration. I am not sure if the 3pt works when the backhoe is hooked up to the tractor and plugged in - I never tried playing with it to see if the arms move or not. If I get a chance this weekend I will hook up the backhoe and see what happens. I have the service manual - that might have some insight too.
I guess I need some insight into how hydraulics function - I understand that "power beyond" is high pressure that feeds thru the valve in question to power other hydraulics down the line - I get sort of lost though trying to figure out where the "low pressure return" comes from. Does hydraulic pressure always go down after you push it thru a valve? In other words when the backhoe is hooked up to the back of the BX is the return hose a low pressure hose - and if the backhoe is not hooked up and the loop is connected I get high pressure to power hydraulics down the line - like the 3pt?
   / Hydraulic joystick - would this work? #12
The 3pt works when the backhoe is connected. The 3pt hitch operates the mid mower deck linkages, and it also operates when the hoe is attached.
   / Hydraulic joystick - would this work? #13
</font><font color="blue" class="small">( I guess I need some insight into how hydraulics function - I understand that "power beyond" is high pressure that feeds thru the valve in question to power other hydraulics down the line - I get sort of lost though trying to figure out where the "low pressure return" comes from. Does hydraulic pressure always go down after you push it thru a valve? In other words when the backhoe is hooked up to the back of the BX is the return hose a low pressure hose - and if the backhoe is not hooked up and the loop is connected I get high pressure to power hydraulics down the line - like the 3pt? )</font>
A simple explanation:
A low pressure return line is used to carry exhaust fluid from the cylinder that is moving. This line typically goes directly to the tank/sump and not back into the high pressure flow path. It is not good practice to attempt to force this exhaust fluid back into the high pressure flow, thus the need for a power beyond outlet.
A valve with power beyond passes high pressure thru the valve when spools are in neutral and has an additional outlet for the low pressure exhaust from the cylinders.
A valve without power beyond has the low pressure return and the high pressure pass thru tied together in the valve. This setup is used when there is no other valve after this one, meaning the outlet goes directly to the tank.
I am not familiar with the hydraulic circuit for the BX23 which is why I asked the question. Typically the 3pt is the last valve in the circuit. Some configurations have the 3pt disabled, usually with a break in the circuit via a hose being connected or not, whenever the backhoe is connected.
I had a chance to get into my tractor storage shed and move the implements around this weekend so I could get to the backhoe. The backhoe is now hooked up to the tractor and the 3pt arms do move when the backhoe is attached. So apparently the 3pt is not disabled when the backhoe is attached. I also dug out the shop manual and found a hydraulics schematic for the tractor - if I can get it scanned in I will post it - it didn't quite make sense to me.
   / Hydraulic joystick - would this work? #15
Hi...just a thought here, but you might want to look at selector valves as an alternative. I wanted to add a third hydraulic circuit to my PT to curl/uncurl a front hoe attachment, but the existing joystick valve only had two spools (raise/lower front lift arms, curl/uncurl large bucket). I added a boom and the hoe bucket was on the end of that, so the curl/uncurl large bucket now curled/uncurled the boom arm, if this makes sense. So I needed a third control to curl/uncurl the hoe bucket at the end of the boom (the third hydraulic cylinder). So, I installed a solenoid-operated selector valve between the boom curl circuit and the spool for that circuit. I move the joystick left or right to curl/uncurl the boom, and move the joystick left or right while pressing a thumb button to curl/uncurl the hoe bucket. This might work for you...there's no question about whether a selector valve will work problem free without physics getting in the way! /forums/images/graemlins/cool.gif Hit the URL in my sig...there's a hydraulic schematic showing what I did...pretty simple.
HTH,
Dave
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2008 Chevrolet Impala Sedan (A55758)
2008 Chevrolet...
Giyi 77" Sweeper (A53316)
Giyi 77" Sweeper...
275 Gallon Fuel Tank (A50775)
275 Gallon Fuel...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
