Hydraulic leak on fel
   / Hydraulic leak on fel #1
siebo
SW Michigan
I have an hydraulic leak on the fel of my L3130. The leak is coming from one of the cylinders that control the bucket. I called my dealer and was told that Kubota is aware of the problems they are having with these cylinders and it would be replace under warrentee. I then asked since Kubota knows of this problem, why not replace both cylinders even though one is not leaking. I was told that they will only replace the leaking one. I was then told that I would have to pay for the service call to get it fixed. Two questions. First, why wouldn't Kubota replace both of the cylinders, especially if they know of the problem?. The dealer told me that there is a 50% chance of the good one going bad. Second, why wouldn't the cost of the service call be passed on to Kubota? I don't want the dealer to be stuck with this cost either but I don't think I should have to pay for it.
   / Hydraulic leak on fel #2
Had to change out the bucket curl cylinder on my bx under warrantee. It was very simple to remove. I took the cylinder to the dealer and they handed me one free of charge. Realy, It took less than five minutes to change out. Might want to consider changing it yourself rather than hauling your tractor to the dealer. If you have any questions on the proceedure send me a pm.
   / Hydraulic leak on fel #3
Siebo:
I had the same problem with my 3130. I have the LA723 loader, and Kubota ended up replacing five cylinders and gave me two hydraulic oil changes before I had all of the trash out of my hydraulic system. Did you buy the tractor this past summer? If so, it's possible your cylinders are from the same lot as mine.
Rick
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2017 Case TR270 Skidloader (RIDE AND DRIVE) (A50774)
2017 Case TR270...
2022 Weber CR5-II HD Reversible Plate Compactor (A50322)
2022 Weber CR5-II...
